Nous sommes le Mar 23 Déc 2025 08:17
 Sujet du message: Speed up Windows shutdown
Nouveau messagePosté: Ven 13 Oct 2006 11:30
Windows XP stores a couple of values in its registry which are responsible for determining how long to wait before
shutting down open applications and services once the shutdown command has been given.
By editing these two settings and changing them to lower values, you can considerably decrease the amount of
time that Windows XP needs to successfully shut itself down. The first part of this tweak deals with setting the
amount of time Windows will take to kill open applications on shutdown.
Open REGEDIT and navigate to ‘HKEY_CURRENT_USER\Control Panel\Desktop\’
Highlight the ‘WaitToKillAppTimeout’ value.
Set it to ‘1000¢.
Now highlight the ‘HungAppTimeout’ value
Set it to ‘1000¢ also.
The second part of this tip changes the same settings, this time for all users on the system.
Open REGEDIT and navigate to ‘HKEY_USERS\.DEFAULT\Control
Panel\Desktop’
Set it to ‘1000¢.
Now highlight the ‘HungAppTimeout’ value.
In the third part of this tip, we will alter a second registry setting to decrease the amount of time Windows XP will
wait before shutting down active services after receiving a shut down command.
‘HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\’
Highlight the value ‘WaitToKillServiceTimeout’
Change this value to ‘1000.’
This should help to considerably speed up the time Windows XP takes to shut itself down.
Auto kill tasks on shutdown
By default, Windows XP will prompt the user for input if there are one or more applications which have crashed or are not responding and it receives a shut down command. This halts the shutdown process entirely until the user approves the stopping of the non-responsive app.
By altering the registry slightly, Windows XP can be set to close crashed applications automatically. While this does not technically speed up the shut down process, it does streamline it, and ensure that the user will not give the shutdown command then get up and leave, only to find the PC still powered on because Windows never received input on what to do with a hung application.
To allow Windows XP to close non-responsive applications automatically upon shutdown:
Open REGEDIT and navigate to ‘HKEY_CURRENT_USER\Control Panel\Desktop’
Highlight the value ‘AutoEndTasks.’
Change the value to ‘1¢
XP will now be able to close hung applications without user input during the shutdown process.
My Experience
This tweak has really increased my systems shut down speed. I can now shutdown my PC within a few seconds.
j'ai tester et ca fonctionne mon pc prend 3 a 5min pour s'eteindre et maintenant il prend moin de 30sec.
desoler que j'ai pas de temp de tout traduire...
mais je vais esseyer de le faire, je promer rien !
Nouveau messagePosté: Ven 13 Oct 2006 17:43
J'avais teste ces reglages et avec des logiciels tres gourmand en ressources ca coupe , windows leur pete la gueule parce qu'ils ne repondent pas dans le temps impartit sans etre plante .
Nouveau messagePosté: Ven 13 Oct 2006 20:59
moi je ferme le maximum de logiciel avant de l'eteindre, et tout les autres se termine dans le temp impartie :wink:
Nouveau messagePosté: Sam 14 Oct 2006 01:43
bha moi j'ai jamais de souci de fermeture
suis du genre bourrin
tout est ouvert... pas grave "altF4" "Éteindre l'ordianteur" ou " redÉmarrÉ" dans la minute qui suit je suis dÉja en reboot.. (ou Éteind)
notÉ que le pc n'a pas ÉtÉ Éteind depui 33 jour et que je n'ai AUCUN probleme (c'est pas faute de le faire chier)
avec des lecteur virtuel
des fichier vidÉo dans tout les sens
des torrent
des logiciel comme photoshop CS3 et indesign voir mem illustrator (logiciek qui attaque dur)
et 0 probleme :)
remarque depuis le SP2 je n'ai fais AUCUNE mise a jour windows aussi (la seul fois que je l'ai fait le pc tenai pas 2h :?) retour a la normal avec la fonction e bonne configuration :]
Nouveau messagePosté: Sam 14 Oct 2006 10:42
IdÉm aucun mise a jour fait sur le pc depuis SP2 et mn pc s'eteint en moins de 2 , il tourne 10 h sur 24 et travail tout la journÉe .
Arf c'est ta version magique que fait ca max :lol: .
Nouveau messagePosté: Sam 14 Oct 2006 10:44
8)
:lol:
Nouveau messagePosté: Sam 14 Oct 2006 11:34
maxthekiller a écrit:
photoshop CS3
tes sur CS3 et pas CS2 ???? :roll: :?
Nouveau messagePosté: Sam 14 Oct 2006 16:53
photoshop CS3
heu oui de mÉmoire.... (je jurerai pas que c'est le 3 mais je croi bien que c'est ca... je vÉrifierai chez moi car j'ai pas mal d'adobe et je sais plu ou j'en suis :) )
Nouveau messagePosté: Sam 14 Oct 2006 20:56
oui je pense pas que c'est le 3 car le dernier est le 2, le 3 n'existe pas encore lol :wink:
Nouveau messagePosté: Sam 14 Oct 2006 23:38
oui oui effectivemnt :]
:oops:
:sac:
