[phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Notice: in file /includes/functions_content.php on line 652: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Notice: in file /includes/session.php on line 942: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3633: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3635: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3636: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3637: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
Supracars • Afficher le sujet - Trop de pression tonton!! ( jauge/pige d'huile)
Nous sommes le Sam 4 Juil 2026 16:24
Poster un nouveau sujet Répondre au sujet  [ 35 messages ]  Aller à la page 1, 2, 3  Suivante
 Sujet du message: Trop de pression tonton!! ( jauge/pige d'huile)
Nouveau messagePosté: Mer 14 Mar 2018 18:08
vos attentes:
Bonjour,j'ai un petit souci.J'ai la jauge d'huile moteur qui sort de sont logement quand j'accelere trop fort ce qui a pour effet d'envoyer parlasuite de l'huile dans le conpartiment moteur ( bonjour l'odeur) et par logique faire un manque d'huile dans mon carter moteur.
Jeme suis donc rendu chez toy pour acheter une jauge a huile ref:1530142021 au prix de 22eu.Le probleme est qu'elle n'est plus diponible dans tous le reseau toy et n'est plus fabriquee.
Quelqu'un aurais un plan ,une idee ou une jauge neuve a brasser??
cdlt
 Sujet du message: Re: Trop de pression tonton!! ( jauge/pige d'huile)
Nouveau messagePosté: Mer 14 Mar 2018 18:33
vos attentes:
C'est quand-même étrange que ton huile remonte avec assez de pression pour sortir ta jauge. D'ailleurs, l'huile n'est pas censée remonté jusque la. Tu es sur que tu n'en a pas mis un peu trop?
Sinon j'ai une jauge de GE en stock mais pas neuve.
Nouveau messagePosté: Mer 14 Mar 2018 20:20
vos attentes:
Salut,en fait c'est le ''joint''qui es use et qui retiens pas assez.Le mecano,m'a donne une petite astuce qui peu depanner a court therme: nettoyer le joint et l'entree du tunnel au nettoyant frein,...c'est vrai ,ca accroche mieux mais la retenue reste ( trop) faible.
Et pour la pression ,j'ai un moteur qui totalise 130 000 mais qui a ete entierement ressurface et rejointe (culasse,bloc,carter) a 125 000km alors peu etre que ca + ca...... :?:
Nouveau messagePosté: Jeu 15 Mar 2018 15:18
vos attentes:
Tu as essayé chez ?
Elle est à 14.48€ hors fdp.
Nouveau messagePosté: Jeu 15 Mar 2018 15:36
vos attentes:
Salut stouf,non je n'y ai pas pense.Elle est a 13,99 avec 14,52 de fdp.
Merci.
J'ai trouve une astuce,j'ai mis un bout de gaine thermoretractable sur le premier torique (le plus haut).
Nouveau messagePosté: Jeu 15 Mar 2018 20:17
vos attentes:
Cool, bah si ça tient c'est nickel. :wink:
Nouveau messagePosté: Mar 27 Mar 2018 07:30
vos attentes:
Salut,je viens de remarquer un truc avec les jauge d'huile ( je sais que l'on en parle qlq part sur le fofo).
J'ai remarque que la jauge de ma sup de decembre 87 est plus courte de 5mm et par ce fait la limite d'huile plus haute de env.5mm que la jauge de ma sup de novembre 86.
Ce que je voudrais savoir est: est ce toyota qui a fait ce changement (officiel)lors de la refonte du dexieme semestre de 1987 pour tous les models ou le proprio qui etait au courant du fail de cette jauge....?
Nouveau messagePosté: Mar 27 Mar 2018 13:12
vos attentes:
Je sais que Toyota a modifié ses jauges pour les MKIII, mais ils n'ont pas rappelé les voitures pour les équiper.
Ces jauges étaient disponibles en remplacement, mais j'ignore à partir de quelle année.
En haut l'ancien modèle et en bas le nouveau.
Nouveau messagePosté: Mar 27 Mar 2018 17:15
vos attentes:
salut stouf.J'en ai aucune qui ressemble aux tiennes.Les miennes se ressemblent,mis a part le trait plus haut de 4-5 mm
Nouveau messagePosté: Mar 27 Mar 2018 18:04
vos attentes:
Si tu en as aucune qui ressemble, est-ce que ta jauge est vraiment d'origine à ce moment là. Est-ce que ce n'est pas une jauge rapporté, et là forcément ça poserai problème...
Nouveau messagePosté: Mer 28 Mar 2018 13:26
vos attentes:
Nouveau messagePosté: Mer 28 Mar 2018 14:16
vos attentes:
Re,je vais essayer de poster des tof(mais il faut que je passe par mon voisin,ce qui me gene un peu).Ce qui m'etonne c'est que mes jauge ressemble a l'ancienne ( en bout) mais est plate sur tout le long ,ensuite mes jauges viennent de 2 supra differente,(1986 et 1987) et accessoirement toutes francaise....En tout cas rien a voir avec celle de 92 ,rien que la poignee.....
Nouveau messagePosté: Mer 28 Mar 2018 14:20
vos attentes:
Au fait pour les tof ,y a t'il une resolution max a ne pas depasser,ca passe en 9m de pixel?
Nouveau messagePosté: Jeu 29 Mar 2018 19:26
vos attentes:
Voici les photo de mes jauges :
La jaune est de 1987, et l'autre de 1986.
On dit merci au voisin :lol:
Nouveau messagePosté: Jeu 29 Mar 2018 20:05
vos attentes:
J'ai oublie de preciser que sur la ''noire'' il y a grave le chiffre 6 et sur la jaune 7
Poster un nouveau sujetRépondre au sujet  [ 35 messages ]  Aller à la page 1, 2, 3  Suivante
