[phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Notice: in file /includes/functions_content.php on line 652: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Notice: in file /includes/session.php on line 942: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3633: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3635: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3636: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3637: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
Supracars • Afficher le sujet - [MKIII] Renseignements svp
Nous sommes le Sam 4 Juil 2026 16:40
 Sujet du message: [MKIII] Renseignements svp
Nouveau messagePosté: Jeu 30 Mar 2017 18:36
vos attentes:
slt a tous j'ai fait un peu le tour du forum sans trop trop de réponses a mes questions ,
- Tout d abord je recherche un bouchon de liquide de direction sur ma mk3 , introuvable et toyota ma envoyé le mauvais ...
- Ensuite j ai changé le liquide de refroidissement on ma conseillé le violet de chez vw vous en pensez quoi ?
- Et pour finir je fais la vidange demain quelle quantité d'huile dois je remettre ?
merci !!!
 Sujet du message: Re: RECHERCHE DE PIECE
Nouveau messagePosté: Jeu 30 Mar 2017 20:15
vos attentes:
Pour le liquide de refroidissement, moi, je mets le premier que je trouve, toute facon on démonte tellement souvent que tu fais la vidange quasiment tout les ans. :mrgreen:
Pour l'huile, tu as tout la dessus
et le bouchon de radiateur, turbo ou atmo? car la pression de décharge varie.
 Sujet du message: Re: [MKIII] Renseignements svp
Nouveau messagePosté: Mar 4 Avr 2017 17:52
vos attentes:
Déjà, quand tu as besoin d'un ou plusieurs renseignements, pour voir si ça a déjà été évoqué, fais un tour ici: .
Ensuite, tu peux utiliser la fonction "" du forum, au dessus de la bannière.
- Pour le bouchon de réservoir de liquide de direction assistée:
Effectivement sur les schémas que je trouve pour la MKIII, ils montrent un bouchon d'atmo (c'est pas les mêmes que les turbo).
Je suppose que tu as une turbo (1990) avec bouchon métal, et qu'ils t'ont donné un bouchon d'atmo en plastique.
Toyota a du te donner celui là: http://www.cygnusx1.net/Supra/Library/EPC/291420/catalog.aspx?F=4502&P=1
Au lieu de celui là: http://jp-carparts.com/toyota/part_detail.php?maker=toyota&type=311140&cartype=55&fig=4502&part=1891655
Le truc c'est que les 2 types de bouchons ont les mêmes références apparemment... (44305-30020)
Du coup je ne sais pas comment avoir le bon bouchon... :roll:
Éventuellement passes une annonce ici:
- Pour le liquide de refroidissement, même avis que Mikl, même du bas de gamme de supermarché fait l'affaire, à voir les conditions de gel dans ta région.
- Pour les quantités d'huile:
7M-GE :
4.1L sans changement du filtre
4.4L avec changement du filtre
4.9L Moteur Sec
7M-GTE :
5.1L Moteur Sec
Voilà. :wink:
Nouveau messagePosté: Mar 4 Avr 2017 18:16
vos attentes:
Nouveau messagePosté: Mer 5 Avr 2017 11:28
vos attentes:
Nouveau messagePosté: Mer 5 Avr 2017 11:39
vos attentes:
Moi j'ai la ref suivante pour le bouchon de radiateur de MK3 Turbo.
16401-72090
Nouveau messagePosté: Mer 5 Avr 2017 19:50
vos attentes:
Oui sauf qu'on parle du bouchon de bocal de direction assistée... :wink:
Nouveau messagePosté: Jeu 6 Avr 2017 10:14
vos attentes:
Au temps pour moi je ne sais pas pourquoi j'ai lu radiateur ? :lol:
Du coup j'ai la même référence que vous, 44305-30020.
Nouveau messagePosté: Jeu 6 Avr 2017 12:17
vos attentes:
Nouveau messagePosté: Jeu 6 Avr 2017 12:23
vos attentes:
En fait, d'après Thomas (The2jakes ici) sur Facebook (je crois qu'il a remplacé bocal + bouchon par un neuf), j'ai l'impression que le bocal acier ne se fait plus et a été remplacé par un plastique, pareil pour le bouchon.
Mais Thomas a gardé son ancien bocal acier avec le bouchon, donc Yo Pneu doit pouvoir se démerder avec Thomas. :wink:
Mais conclusion: ne surtout pas perdre son bouchon acier de DA !!! :mrgreen:
Nouveau messagePosté: Jeu 6 Avr 2017 12:50
vos attentes:
