[phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Notice: in file /includes/functions_content.php on line 652: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Notice: in file /includes/session.php on line 942: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3633: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3635: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3636: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3637: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
Supracars • Afficher le sujet - ajouter des ventilos aux radiateurs de la MK3
Nous sommes le Lun 29 Juin 2026 16:55
 Sujet du message: ajouter des ventilos aux radiateurs de la MK3
Nouveau messagePosté: Jeu 16 Sep 2010 18:47
vos attentes:
salut!
Je n'est pas trouvé le topic je ne sais pas s'il existe. si c'est le cas , je m'en excuse
voila j'aimerai monter 2 ventilateurs en + sur le radiateur de ma MK3 (il y a des emplacement à cet effet)
quelqu'un l'as déjà fait?
merci
 Sujet du message: Re: ajouter des ventilos aux radiateurs de la MK3
Nouveau messagePosté: Jeu 16 Sep 2010 18:53
vos attentes:
Normalement d'origine sur le modèle que tu as il y a déjà deux ventilos électriques, qui servent en ventilos d'appoint et pour la clim.
Si ils n'y sont pas c'est qu'ils ont été enlevés.
Tu aurais une photo?
Nouveau messagePosté: Jeu 16 Sep 2010 20:47
vos attentes:
je le prendrait en photo.
la clim a été enlevé donc je pense que les ventilos (je viens de l'acheter) aussi mais je trouve ca un peu stupide de les virer
par exemple si le moteur est très chaud, et que le véhicule a l'arrêt moteur éteint les ventilos devraient s'activer un moment il me semble
puis si on fais un peu de ville, il est un peu stupide de ne pas utiliser ces emplacements non?
merci pour ta réponse
Nouveau messagePosté: Ven 17 Sep 2010 00:35
vos attentes:
Effectivement s'ils ont été retirés c'est stupide, car ils ne servent pas qu'à la clim.
En cas de grosse chauffe ils se déclenchent pour épauler le ventilo principal.
Nouveau messagePosté: Ven 17 Sep 2010 08:55
vos attentes:
oui et justement, il est facile d'en replacer même venant d'un autre véhicule, je pense que j'arriverais a les adapter, mais il me faut placer des capteurs de températures au niveau du radia pour qu'ils puissent se déclencher et je ne sais pas s'il y a des emplacements prévu a cet effet, toi qui a tout les ventilateurs sur ta MK3, crois tu pouvoir jeter un coup d'œil au câblage un de ces 4 (si sa se trouve, les capteurs sont encore présent sur mon véhicule, il me suffit de raccorder les ventilos, mais ou??) si la pers a qui j'ai acheté la supra était plus joignable aussi....
merci
Nouveau messagePosté: Ven 17 Sep 2010 12:22
vos attentes:
Nouveau messagePosté: Ven 17 Sep 2010 15:51
vos attentes:
Sur atmo je ne sais pas.
Sur turbo je crois me rappeler que c'est la sonde qui est en bas sur le support de calorstat.
Ce qui est sûr c'est que c'est le connecteur bleu foncé.
Les deux flèches sur la photo.
Pour tester tes ventilos électriques, tu déconnectes la sonde, et tu relies le connecteur bleu à une masse.
Contact mis, tes ventilos doivent tourner.
Sur ma grise, la sonde était morte (du moins j'ai présumé car ça faisait comme toi, les ventilos ne tournaient jamais) et j'avais relié le connecteur à la masse via un interrupteur au tableau de bord.
Comme ça, en cas de forte chaleur ou de ballade en ville ou bouchons, tu enclenches tes ventilos électriques toi même.
Si tu veux qu'ils tournent direct au démarrage du moteur il te suffit de relier directement le connecteur bleu à la masse.
La sonde coute cher (+ de 90€ chez Toy je crois). :?
Mais je ne sais pas comment la tester.
Par contre, si ton ventilo principal ne fonctionne pas, les deux ventilos électriques ne suffiront pas, je pense que ton visco-coupleur est DCD et il faut le changer.
Nouveau messagePosté: Ven 17 Sep 2010 19:31
vos attentes:
merci pour l'info je vais voir si je trouve quelque chose qui ressemble a ca sur la mienne et oui le visco est mort mais j'en ai un autre :wink:
Nouveau messagePosté: Ven 17 Sep 2010 20:26
Nouveau messagePosté: Ven 17 Sep 2010 21:14
vos attentes:
si tu as pour atmo ca m'interresse
Nouveau messagePosté: Sam 18 Sep 2010 02:50
vos attentes:
Nouveau messagePosté: Sam 18 Sep 2010 11:28
vos attentes:
Nouveau messagePosté: Sam 18 Sep 2010 12:34
vos attentes:
Bon c'est pas pour t'embéter hein, mais c'est aussi pour tous ceux qui font l'erreur: y'a pas de "H" à ATMO.
C'est l'abréviation d'atmosphérique, voilà.
Donc tu peux re-re-corriger. :wink:
Nouveau messagePosté: Sam 18 Sep 2010 13:25
Nouveau messagePosté: Sam 18 Sep 2010 14:48
vos attentes:
