[phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 368: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Notice: in file /includes/functions_content.php on line 652: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Notice: in file /includes/session.php on line 942: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3633: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3635: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3636: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3637: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
Supracars • Afficher le sujet - les realisations du MGIIC
Nous sommes le Sam 4 Juil 2026 23:00
Poster un nouveau sujet Répondre au sujet  [ 32 messages ]  Aller à la page Précédent  1, 2, 3  Suivante
 Sujet du message: Re: les realisations du MGIIC
Nouveau messagePosté: Sam 12 Fév 2011 10:01
mise en place d'un poussoir de demarreur et reffection de tout le circuit de depression, reglage de hauteur de caisse (tein), freinage arriere, cration d'une admission a venir .
Nouveau messagePosté: Sam 12 Fév 2011 14:19
vos attentes:
Sacré jolie bestiole ! :love:
Nouveau messagePosté: Sam 12 Fév 2011 17:08
vos attentes:
Sympa la civic, c'est un Vtec ?
loin je suis :mrgreen:
Nouveau messagePosté: Mar 15 Fév 2011 22:19
vos attentes:
Très jolie caisse. Bien redoutable sur piste!
Nouveau messagePosté: Mar 15 Fév 2011 23:13
vos attentes:
bon la nsx c de la turie, du reves enfin tous ce qu on veut! Par contre chapeau pour la mini, le boulot que vous avez fais dessus est d enfer.
Nouveau messagePosté: Mer 16 Fév 2011 13:20
merci pour lui, c'est minijacky qui a tout fait sur la mini !
Nouveau messagePosté: Sam 19 Fév 2011 10:07
une EK4 vti bien fournis ...
au programme de la pose:
embrayage exedy stage1
disque percé + ebc red stuff
silent bloc moteur energysuspension
silent bloc train roulant energysuspension
plaque sandwich zenky+ mano T° et pression huile
et alarme avec demarrage a distance .
demontage (destruction serait plus aproprié !!!)et changement des silent bloc de triangle sup et inf avant , barre stab et essieu arriere
pour le demontage, decoupe , poste a souder pour fondre le caoutchouc stock montage à la presse ou au serre joint pour les gros des bras arrieres(comptez 3heures par coté pour découper le vieux et remonter le neuf... evitez de faire ça vous meme car c'est une vrai merde malgré la facilité deconcertante annoncé sur le mode d'emploi!
montage des insert de silentbloc moteur (les 5)
avant et apres montage des inserts :
pour l'alarme avec demarrage a distance, le plus compliqé a été de grugeer le systeme de transpondeur stock , pour faire croire a la caisse que la clé est dans le neiman .
Nouveau messagePosté: Sam 19 Fév 2011 13:05
vos attentes:
Excellent ! :yes:
Moi dans un futur pas encore proche je cherche une alarme avec turbo timer intégré, voir aussi avec démarrage à distance, je sais que ça existe.
Par contre au niveau des marques... :roll:
Nouveau messagePosté: Dim 20 Fév 2011 10:22
Nouveau messagePosté: Dim 13 Mar 2011 18:38
voila le collecteur posé sur la s14 , nouveau bruit , nouvelle perf aussi a 55% de duty j'ai la meme pression qu'a 64% avec l'ancien . essai cet aprem , j'adoooore le bruit.
Nouveau messagePosté: Mer 16 Mar 2011 20:40
maj de la S14 :
pour eviter a la ligne de trop travailler et de peter le nouveau collecteur, installation d'un torque damper plutot solide:
ça devrait plus bouger , maintenant !!!
Nouveau messagePosté: Lun 12 Sep 2011 20:19
maj de la s14 :
amortisseur kyb agx +ressort eibach
reglage arriere sur 5 et avant sur 3 . J'ai pris des routes refoncés , pour essayer , c'est mois confortable c'est sur , mais la voiture est meconnaissable , moins de roulis , moins de pompage, la voiture est presque sur un rail .
pose turbo gt2871r
durite renforcé
admi modifié
radiateur alu
pare flamme maison avec articulation
obligé de modifier la sortie d'huile plus du tout adapté:
perçage du collecteur pour integrer la sonde EGT
mise en place de vis reforcé modifié pour monter sur la downpipe
remontage de l'ensemble avec les durites renforcées
et la sonde egt
creation du piping admission , avec modif de la pompe de DA pour tout passer
soudure de la flange du nouveau parefeu
surprise... a cause du couple tres tres elevé , je me retrouve avec une fuite a la boite . je change donc le joint spi de sortie, mais ça sort toujours en cas de tres forte sollicitation .
en fait a l'acceleration l'huile est tellement projeté a l'arriere au coup de pied du au turbo que l'huile refoule par le levier de vitesse !!!
le soufflet est coupé en deux ,
je pose donc un soufflet de cardan universel a la place retaillé au bon diametre et c'est bonnard .
et voila apres nettoyage:
je cours donc essayer en augmentant un peu la pression et du coup j'ai encore grapillé du chrono .
70-180 en 10sec
120-180 en 6sec
et le radiateur :
l'afficheur EGT est encastré :
Nouveau messagePosté: Lun 12 Sep 2011 23:06
vos attentes:
Beau Boulot.
Ou pinaise un Tru Boost AEM, je vais pouvoir voir comment ça marche bien avant d'en acheter un ^^
Nouveau messagePosté: Mar 13 Sep 2011 03:39
vos attentes:
Encore du très beau taf ! :yes:
Nouveau messagePosté: Mar 13 Sep 2011 07:48
assez difficile de trouver quelques heures a y consacrer, vu le reste des travaux , pour monter tout ce qu'il y a sur le dernier post, ça m'a pris a peu pres 3 mois, et la carto est toujours pas aiguisée .
pour redskins , oui, tu va voir de pres , c'est pas trop mal , le seul defaut c'est le gain qui est pas reglable, du coup si les autres parametres sont pas reglés au quart de poil , tu te prends des pics de 100 a 150gr ( a 1.3bar quand meme)
Poster un nouveau sujetRépondre au sujet  [ 32 messages ]  Aller à la page Précédent  1, 2, 3  Suivante
