Apres de nombreuse recherche sur le E-MANAGE, j ai reusi a trouver certaine reponse a:
peut on supprimer le debimetre ? oui on peu car il peu gerer le montage d un turbo sur une atmo. pour cela, il faut la sonde de pression ou le partage de la sonde du PROFEC E-01.
il y a 3 reglage derriere la facade qui sert pour configurer le type de voiture. le E-MANAGE utilise ces informations pour déterminer comment interpréter le signal de débit-mètre et le signal d'allumage.
a l interieur, il y a des cavaliers a bouger en fonction des options choisie.
JP1 Ignition input pullup/pulldown select
1-2 A resistor is pulled down to ground
2-3 A resistor is pulled up the +ve rail
* Use 1-2 when the ECU's driver transistor is connected to ground
* Use 2-3 when the ECU's driver transistor is connected to +ve (5V or 12V will determine JP2's setting)
Supposedly you can see the input voltage in the Main Unit Setting Information window. If it's 0v, use 1-2. If it's 5v or more, use 2-3.
JP2 Ignition output select
1-2 Output resistor connected to +5V
2-3 Output resistor connected to +12V
* This will depend on the ECU ignitor signals output
* JP2 enables the e-manage to duplicate the amplitude of the original signal
JP3 airflow/VTEC output select
1-2 2nd airflow meter
2-3 VTEC
* Even if you don't have a 2nd airflow meter, leave it on 1-2 for non-VTEC applications
JP4 airflow/VTEC input select
1-2 VTEC
2-3 2nd airflow meter
* Even if you don't have a 2nd airflow meter, leave it on 2-3 for non-VTEC applications
* On 1-2, enables pulldown resistor (for use as VTM signal). This is required because the VTM output is inverted with the VTEC out.
JP5/JP6 Sub injector drivers
Jumper off - Disabled
1-2 - Enabled
* Only enable if you're going to control extra injectors with the E-manage
JP7 VTEC
1-2 Non-VTEC
Jumper off - VTEC
* On 1-2, enables pullup resistor (for use as MAF output)
par contre il y a un petit probleme avec le systeme d allumage du 7MGTE et le E-MANAGE a du mal a le gerer mais il existe un remede a cette situation que je comprend pas trop pour le moment
si quelqu un comprend cela m aiderai bien
