Sujet du message: Re: Bonne affaire ou arnaque????
Posté: Ven 26 Aoû 2011 07:26
Localisation: LES ROUSSES (39) vos attentes: Le printemps, il y trop de neige pour rouler
la différence vient surtout des internes moteur apparemment :
the 75-78 280Z's all had N42 block dished pistosn L28's, the 75 got the desirable N42 head and the latterr ones got the less desirable N47, basically the same except the N47 has restrictive sleaves in the exahaust runners, but the N42 block is accepted and the strongest block as all 6 cylinders are siameased together, these were all around 8.5:1 IIRC
the 280zx all got the F54 block, the 79-80 got the lower comrpession dished pistons wiht the high low compression P79 head aso with sleaved exhaust runners, these were around 8.0:1 IIRC the 81-83 n/a gto flat top pistons in the same F54 block with the same P79 head, these were arounf 9.0:1 IIRC int he F54 only every other cylinder is siameased
the 81-83 turbo came with the F54 block with low compression dished pistons and a low compression P90 head, but these had no linders int he exhaust runners, these were 7.3:1
_________________ Les tractions, c'est comme les homosexuels : on peut prendre du plaisir avec, mais c'est pas prévu pour !
