[phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 472: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Notice: in file /includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Notice: in file /includes/functions_content.php on line 652: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Notice: in file /includes/session.php on line 942: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3633: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3635: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3636: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3637: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2984)
Supracars • Afficher le sujet - chercher boite a fusible
Nous sommes le Dim 5 Juil 2026 05:00
Poster un nouveau sujet Répondre au sujet  [ 41 messages ]  Aller à la page Précédent  1, 2, 3  Suivante
 Sujet du message: Re: chercher boite a fusible
Nouveau messagePosté: Sam 10 Juil 2010 09:12
vos attentes:
Nouveau messagePosté: Sam 10 Juil 2010 12:18
vos attentes:
Merci JuLT08.
Nouveau messagePosté: Sam 10 Juil 2010 13:02
vos attentes:
normalement la boite a fusible dans l'habitacle ce trouve coté conducteur( a verifier si ca ce trouve sur une JDM elle est coter passager!!)
c'est une toute petite boite noir, grande comme un paquet de cloppe!
il faut enlever le repose pied pour une conduite a gauche, donc sur la tienne il doit falloir sortir le cache en pastique qui fait tout le long de la moquette!
Nouveau messagePosté: Sam 10 Juil 2010 18:02
vos attentes:
voila j ai trouve la boite a fusibles elle est bien cote chauffeur toute au font mais tout les fusibles ont l aire bon
donc je sais pas ou je peut encore chercher car avant ca allais?
Nouveau messagePosté: Dim 11 Juil 2010 12:36
vos attentes:
tu n'as plus d'éclairage ou?
les pahres? ou tableau de bord? ou ventilation?
tu a vérifier les relais dans le compartiment moteur?
Nouveau messagePosté: Dim 11 Juil 2010 19:46
vos attentes:
ben quand je coupe le contact ils y as plus rien qui s allume meme pas le plafonier et je sais pas comment faire pour verifier un relay
Nouveau messagePosté: Dim 11 Juil 2010 23:34
vos attentes:
je ne te serais pas vraiment d'une grande aide pour ce qui est de vérifier un relais!!!
au pire tu en prend un identique a coter et tu essaye!
sinon pour ce qui est du plafonnier ca pourrai aussi venir du capteur de porte!
Nouveau messagePosté: Lun 12 Juil 2010 10:36
vos attentes:
non car meme quand j essaye de l alumer manuellement ca va pas
Nouveau messagePosté: Lun 12 Juil 2010 12:24
vos attentes:
Et lorsque tu as le contact de mis, tout marche bien?
Nouveau messagePosté: Lun 12 Juil 2010 20:51
vos attentes:
Nouveau messagePosté: Lun 12 Juil 2010 21:07
vos attentes:
pour moi, c'est plutôt ce a quoi je pense depuis le début, ton alimentation est branché sur le + après contact au lieu du + permanent.
enfin c'est ce que je pense et tu as donc une modif qui a mal été faite ou au niveau moteur ou dans l'habitacle.
Un relais ou un fusible n'a rien a voir la dedans.
Quel modif de n'importe quelle sorte as tu sur ta voiture et depuis quand?
Nouveau messagePosté: Mar 13 Juil 2010 12:21
vos attentes:
Nouveau messagePosté: Mar 13 Juil 2010 13:04
vos attentes:
et ces leds, tu as remis l'identique a l'origine ou il a fallu toucher aux fils?
tu as peut être coincé des fils lorsque tu as tout remonté? (je ne sais pas s'il faut démonter les plastiques du volant, d'ou la suite)
re-démonte et test, retire les leds et test, vérifie tes fils etc...
Le problème doit venir de par là, car un fusible ou relais, quand c'est mort, y'a plus rien du tout avec ou sans contact.
Nouveau messagePosté: Mar 13 Juil 2010 15:10
vos attentes:
non rien n est coince et j ai vire la leds et ca va tout jours pas
Nouveau messagePosté: Mar 13 Juil 2010 15:39
vos attentes:
et tu n'as que ça comme modif. faite par toi ou le prédécesseur de cette voiture?
Comme je te l'ai mis plus haut, un branchement d'origine (je pense a un + permanent) a dû être défait et reconnecté sur un + après contact.
Je ne voie que ça pour le moment.
Je vais chercher ailleurs de mon côté!
Poster un nouveau sujetRépondre au sujet  [ 41 messages ]  Aller à la page Précédent  1, 2, 3  Suivante
